This is generally a sign that the control board in unit is bad. They are not cheap. http://www.appliancepartspros.com/ge-board-with-core-wr55x10942p-ap6048447.html
SOURCE: Ice & water dispenser not working
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
SOURCE: ice and water dispenser not working
ALWAYS MAKE SURE YOUR APPLIANCE IS UN PLUGGED BEFORE TRYING ANY PROCEEDURES !!!!!! MAKE SURE THE WATER SUPPLY VALVE (SOMETIMES 1/4" SADDLE TYPE PEIRCING VALVE) IS NOT CLOGGED WITH SEDIMENT... THEN MAKE SURE THE WATER SOLENOID IS NOT CLOGGED AS WELL ... THE WATER SUPLY SOLENOID HAS A SMALL ORFICE THAT CAN BECOME PARTIALLY CLOGGED OR DOES NOT "SEAT PROPERLY" AND CAN CAUSE INSUFFICIENT WATER SUPPLY AND THUS ERRATIC OPERATION. A LARGE PERCENTAGE OF WATER DISPENSER AND ICE MAKER PROBLEMS ARE DUE TO INADEQUATE WATER SUPPLY. IT IS THE FIRST THING THAT NEEDS TO BE CHECKED !!!
SOURCE: Maytag msd2556aew
no ice maker on its own circet how are you hooked up to your house saddle valves plastic pipes turn your main line off take it loose get a bucket turn it on and check the flow
SOURCE: GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
SOURCE: Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
