SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
SOURCE: New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
SOURCE: LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
SOURCE: my 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
