Question about Panasonic Lumix DMC-FS4 Digital Camera
No image was shown on screen while i still can take photo.
  • 313 Answers
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • Posted on May 11, 2011
    6ya staff
    SOURCE:
    The photos taken by my camera are fuzzy, unclear
    Try to hold the camera more properly. Disable flash if enough light is there. Hold on the capture button for a while and dont move the camera until the captured image is shown on the screen for review.
    Sep 16, 2012 | Sony Cyber-shot DSC-W190 Digital Camera
    Tip
    Stop Receiving Notifications From Facebook Friend Photo
    Many times when you comment on a photo your friend uploaded, and some other may start commenting after you and everytime it receives a comment you get a notification mail in your email inbox or you get notified in facebook.
    This can be really annoying for some, you can configure such option on facebook which will stop all these notification in such case when someone comments after you on the same photo.
    Follow the procedure to do it.
    1. Login to facebook.com
    2. Go to facebook account settings as shown in the image below
    3. Now click Notifications Tab and Scroll down to locate the following options under photos - Deselect Comments after you on a photo and Comments after you on a photo album options under the Photos section as shown in the image below.
    4. Once you have unchecked these two options, scroll down and click Save Changes button at the bottom of the page to save these options you configured.
    That's it you have finished.
    on Sep 17, 2010 | Facebook Social Network
    I need to delete photos on my ipod
    Press the circular button at the bottom of the screen to power on the device. Slide your finger across the "Slide to Unlock" option.Click the "Photos" icon on the screen. This icon has the image of a sunflower on it.Click the "Camera Roll" tab to be shown all of the images stored on your iPod touch. Scroll through the pictures and select one you want to remove by pressing it with your finger. This brings the image up into full screen mode.Press the small trashcan icon in the lower right corner of your device. Two options appear on the screen. From the options select "Delete Photo." This removes the image from your iPod touch.
    Jul 21, 2011 | Apple iPod touch
    When i view my photos on my camera they come up with 'read error'
    Sounds like the card is failing - try recovering the images with a free software package - Google will find you lots - then Format or discard the card. Format in the camera - NEVER format using a computer
    Jun 02, 2010 | Fuji FinePix S3100 Digital Camera
    Heads off photos
    It is the borderless setting that does this, cause in actual fact, all borderless does is strectch your image.
    If you remove the borderless setting, you will get the heads back
    Unfortunately there is no way around this. Just keep this in mine when taking your next photo's.
    Aug 07, 2008 | Epson Stylus RX650 All-In-One Printer
    LCD screen shows weird colours
    Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
    Why has nobody commented?
    How much to replace screen? Any ideas?
    Feb 16, 2008 | Cameras
    Problem with image resolution
    hi
    do the image is is also decrease or u feel that image resulation is low by quality if u tell me more then may be i say u something more about it.
    Oct 26, 2007 | Nikon D40x Digital Camera
    Date and time on images taken
    On the back of the camera there should be a button that looks like two vertical lines with a rounded box in the middle (or sometimes the OK or SET button). pressing this a number of times will show various lcd screen view modes. One of these settings will be off alltogether. Don't worry, keep pressing. There should only be 3 or 4 different settings, one with the photo information.
    Sep 13, 2007 | Canon PowerShot A450 Digital Camera
    Red Screen
    you camera is experiencing CCD image sensor failure, very common problem with Canon cameras, Canon offer free repair, follow this link: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=10462&keycode=2112&id=29819
    Aug 19, 2007 | Canon PowerShot A85 Digital Camera
    Blurry screen, takes ok pictures
    Well you may be right or yet another dud screen Canon support will advise - but as it has been repaired previously- it may be time to replace it
    Apr 22, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
    Panasonic Lumix DMC-FS4 Digital Camera Logo
    154 people viewed this question
    Top Panasonic Cameras Experts
    Ekse
    rajiv6089
    Level 1 Expert
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
