I was given a used 37 inch Sharp Aquos. It reads "Failed to receive Broadcast [E202]" .
Ive searched a couple spots to see what this error message is but can't find it ..... anyone know what's supposed to be done?
I tried my direct tv cable on another tv and it works just fine. Can't seem to get signal in this TV
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Well I tried a cable amplifier & that solved my problem. I now get all HD channels without an HD cable box.
Menu - setup - reset the whole tv and start a new search. Worked fine for me.
Just have basic cable. Only one cable to antenna. Signal pops up Cable - Digital 3.1???? No idea!
SHARP sucks.
I also have a Sharp Aquos & just two digital channels that [E202] shows up on. Channel 5 (FOX) & Channel 4 (NBC). I think it just a weak signal for those channels. I'm going to try a cable booster to see if that works.
