Does anyone out there in tech-world know the exact amperage for the two fuses in a Philips 37"LCD TV model 37PF7320A? The fuses are approximately 1 inch long with the following markings: T5AH 250V (ceramic fuse) & T1AE 250V ( glass fuse. I am assuming that T5AH means 5amp & T1AE means 1 amp. i put the tv on and nothing is happening
Is the fuse in the plug okay?
If the fuses are not blowing when you are turning the tv on, this suggests that the PSU primary side is okay.
Since you have opened the TV up, I would suggest probing around with a multimeter however I do not want to let you harm yourself or the TV.
Look for any:
http://en.wikipedia.org/wiki/Capacitor_plague
on the power supply
I have a Magnavox 37MF231d LCD TV and have the same problem. Except, I can only find the ceramic T5AH 250V fuse on the power board. Should I also have a clear fuse? If so, wouldn't it also be on the power board?
