use a brass drift and hammer, to remove the cam locking ring from the fuel tank by rotating it counterclockwise. Carefully lift the fuel tank sending unit and pump from the fuel tank.
Remove the fuel pump from the sending unit: Slide it upward onto the mounting tube, then slide the bottom of the pump away from the bottom support. Slide the pump down to disengage it from the mounting tube.
Remove and discard the rubber O-ring seal between the sending unit and the fuel tank. Slide the new fuel pump onto the mounting tube. Make sure the bottom of the pump is seated on the bottom support. Install a new rubber O-ring seal on the sending unit mounting surface on the tank. Lower the fuel pump and sending unit into the fuel tank. Exercise care when doing this. Using the retaining cam tool, reinstall the cam locking ring onto the fuel tank by turning it clockwise
Read more: How to Install a Fuel Pump in a GMC Jimmy ' eHow.com http://www.ehow.com/how_5672181_install-fuel-pump-gmc-jimmy.html#ixzz1M5wAIdqJ
I remove them with a flat punch and a ball pean hammer gently tap on the ring away from the stops and the ring will rotate off
