Question about Pentax DBC63 Battery Charger AC Plug (39625)
Hi, I've had my Pentax camera and charger for about 3 years now. My charger, model D-BC62 has recently stopped charging the battery. When I insert the battery (model D0LI63) the red light on the unit will turn on and stay study for about 3 seconds, then it starts blinking. When I insert the battery back into the camera it says "Battery Depleted" and turns off. The red charger light continues to blink even after I've removed the battery. Please let me know what the blinking means and if this is a fixable problem. Thank you!
  • Pentax Master
  • 6,218 Answers
The battery is worn out - replace it.
Posted on Apr 28, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Posted on Apr 06, 2008
Anonymous
  • 3 Answers
SOURCE: Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Posted on Jul 25, 2008
Anonymous
SOURCE: I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
Posted on Sep 08, 2009
Ty Price
  • 11967 Answers
SOURCE: Pentax camera showing battery depleted even with
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Oct 27, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: Pentax w30 will not turn on. I think the battery
The flashing light indicates either a charger problem or batteries that are beyond charging. If you have a voltmeter you can check the output of the charger and the voltage of the batteries, but chances are that you just need to replace the batteries -- especially if they're more than a year old.
Posted on Dec 12, 2009
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
Oct 24, 2012 | Pentax Optio Cameras
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I got this camera last June and it's been dead since January. Every time i try to charge it, it will not respond to the charge.The battery is completely dead, but when the charger is plugged into...
Hi, Sounds like the battery is toast. Batteries can stop charging any point in their life span. Usually I'd suggest just buying a new battery but because a battery shouldn't die like that within the first year I'd suggest contacting Nikon in your country and seeing what they'll do for you.
May 18, 2011 | Nikon Coolpix S4000 Digital Camera
Pentax w30 will not turn on. I think the battery may be shorted the light on the charger now blinks instead of staying lit while charging and turning off when fully charged?
Dec 12, 2009 | Pentax Optio W30 Digital Camera
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Pentax DBC63 Battery Charger  AC Plug (39625) Logo
89 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
