Question about Loewe Aconda ACO9303 30" TV
Basically, the TV simply cut out and will not come back on. What can the problem be?
  • Loewe Master
  • 586 Answers
Power Supply board needs replacement or require component level repair by an expert.
Thanks
Posted on May 12, 2011
Blade is not square to table
There are manuals for the Skil 3400 available online.
Centering the blade to the table simply requires a screwdriver, a good square, and some patience. Basically you're loosening up the points that hold it vertically and horizontally (front to back), checking them against the table with your square, and then tightening them up when everything looks nice and ninety degrees.
It's not the best saw in the world, but with a little work, I've been able to get it to make 90 degree cuts and perfect miters with a miter sled and a cross-cut sled I built using aluminum (I think?) T-shaped replacement runners that would normally be used for the worthless miter guide that comes with it.
Apr 23, 2014 | Skil 10" Table Saw 3400
A small cut in the cord and would no work. If you straiten the cord the power reaches the tv. however, on the second time straitening the cord the cord let out a bang and a large spark. Now the tv will no...
You would have to know a little about electrical repairs, if you don't then I suggest finding someone who does because the repair can present electrical dangers.
Some might say to splice the cable around the cut, but I'm not one of them. If the power wire comes from the inside of the TV then you can usually open up the back of the TV and replace the wire with a little soldering. Make sure the wire you use is properly rated for a standard house appliances. (lamp/etc.) If the wire instead simply plugs into the back of the TV then you may just have to contact the manufacturer (or electronics store) to get a replacement wire.
Jan 03, 2014 | Panasonic Televison & Video
Toshiba TheaterWide 57HM167 Won't Turn On After Bulb Replacement
There is a ballast which drives the lamp--a hint would be to try to be in a position if possible to see if lamp ignites at all or even for a moment.
The ballasts do fail but rarely----it develops about 12,000 plus to the lamp and is much like spark plug wires as far as rf.
Some checks would have to be made and then the ballast priced--google the model number with ballast after it to get and idea.
No cut and dried solution here--several possible causes.
Mar 16, 2012 | Televison & Video
Broken lift cable 1994 Coleman Tent Trailer. The cable that lifts it up when you crank it up
Hi well what you need to do is cut a piece of the cable off, and go to a place that stocks and sells nylon cordage, then simply obtain a length that will do the job, then once that's in hand, simply remove all the old cord, and replace with the new one, just reverse whatever you do when you remove the old stuff. It's basically just a bit of rope?
Oct 08, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
My zenith plasma tv popped real loudlike a car backfiring and then the tv picture went black. power on green light wil turn on but it automatically cuts itself back off to the red light
Something blew.... like overheated and just basically blew up..... Was it on for a long time? You may to check your warranty to get it fixed or a new one.... or you may have to just buy a new one....
Jan 09, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Cable connect piece broken mising?
you could take the back off and soilder the connector back on. Or there is an easier way! Simply cut the cable wire end off and just cut the rubber part off and leave the copper wire in the middle and push it in where the cable connector was on the tv and you can actually still pick up a good signal that way you just have to move it around in there till you hit the right spot that picks up a good picture. hope this helps.Happy Holidays!!
Nov 24, 2010 | Orion STV2763 27" TV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Panasonic 32'' TV wont power on
I just received the same model from a neighbour because it too wouldn't power on after suddenly quitting. The T.V. rrepair shops quoted $160.00 to $250.00 to fix the power supply/transformer. All I did was rremove the back and check if the circuit board was actually receiving power from the corsd - it wasn't. I then replaced the plug, plugged it back in and the set works prefectly now. This is a commonm problem with panasonic and certainly does not require the services of a technician, not the exorbatant costs quoted to repair. Simply cut off the plug and replace with a sturdy self sealing/connecting one available at any hardware store for less than $1.00.
Feb 24, 2009 | Panasonic Televison & Video
My connection keeps cutting out.the router is placed in the loft on a desk. and my computer in directly below. my signal is excellent however it simply keeps on cutting out.
basically in my task bar i have my wireless icon and another direct port one which has a red cross on it because i'm not using it. So i disabled it: go start>control panel>classic view>system>hardware>device manager>network adapter>and right hand click the one not in use and disable it. i also went: start>run>cmd>a black box will appear and type in ipconfig/all and thats what i did and it hasn't cut out once!
Aug 27, 2008 | Computers & Internet
TV changes video source randomly
Hi again,
At your convenience, would appreciate an update on status of your concern.
Cheers.
Aug 11, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Loewe Aconda ACO9303 30" TV Logo
103 people viewed this question
Top Loewe Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
