My bmw 318i was parked in town for some few minutes but when i came back to start it it failed and everthing on the dashboard was showing that everthing seems to be fine. what could be the problem and what should i do
That means a fault code has been loaded into the computer memory. You will need to connect a scan tool to the ODBII port and read the code to determine what is wrong.
sounds like a engine sensor i'd guess at the crank sensor but to be sure you would need to get the OBD codes read , this will give the exact fault so wont waste money trying sensor(s) on a hit an miss basis,you can buy a code reader online not expensive just make sure it covers your vehicle make then you have a valuable diag equipment for future use
I had a BMW 540i 2000 and that happen to me, my advice is to get the battery out of the car and recharge it. It would be advisable to have it check for malfunctioning. If it is ok, put it back on and the car will start. If not good, put a new battery, the car will start and all the lights will work in order.
Probably you could loos your radio set up and clock set up if you took too much time in the replacement of the battery, don't worry, reset the clock and the radio stations.
