Microwave Ovens Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Ryan Pries
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on May 12, 2011
Ryan Pries
Expert
Level 2:
Sergeant:
Answers
257
Questions
0
Helped
69398
Points
791
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
Testimonial: "Thank you so much. I've been searching on my computer for an hour to try to find an answer."
Emerson 1.2 CU. FT. 1100W Griller Microwave Oven. How to replace the light bulb for Emerson MWG9115SB please?
Question edited for clarity.
This is what it looks like. A standard SES Appliance bulb
https://www.ebay.com/itm/314808284288
Normally there is a door on the outside case. Some you have to remove all the case. Directions here. Make sure you keep away from the Capacitor and Step Up Transformer as it will make your hair curly.
https://www.wikihow.com/Replace-a-Microwave-Lightbulb
Whirlpool MH2175XST-2 Over the Range Microwave. Can you help me with the proper replacement model?
Question edited for clarity and add MAKER!
Replacements
https://www.google.com/search?q=whirlpool+30+over+the+range+microwave
They all come in standard widths. Any 30" microwave should be fine.
Whirlpool MH2175XST
1.7 Cu. Ft. Over-the-Range Microwave with 1,000 Cooking Watts, Warm Hold Cycle and Sensor Cooking Cycles: Bisque 4.6 quick specs
Style: Over the Range
Width: 29 7/8 Inch
Depth: 15 3/4 Inch
Height: 17 1/8 Inch
Capacity: 1.7 Cu. Ft.
I want to replace an old microwave from 1988: GE Model# JVM130001. What microwave will fit in that space?
Laura, most any over the range microwave should fit that space. It may hang a little below your height but that should not be a problem.
FFHB2740PS
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
1helpful
2answers
Why microwave starts whenever door is opened ?
The micro-switch is loose. Get inside the oven and look for the micro switch and either adjust or replace it.
How do I get a manual & warranty registration card?They were not included in the packaging when I purchased the microwave oven from Target.
The manual is available here: Emerson Radio Corp Customer Support Owner Manuals
At the top of the page is a "Contact Us" link; you can ask them how to register for the warranty. In any case, save your receipt!
2answers
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
