Boss Micro BR Digital Recorder Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not download off br says usb idling.I put card in laptop i think it says unsupported format.2 and 8 gb dont work I took card out of old camara drag pic to laptop no problem.Put recorded music on card And i cant put music on cd I can hear it fine on headphones so i tryed to pull it through phone imput sounds very distorted
Fred Yearian
Level 3:
  • Boss Master 5,603 Answers
  • Posted on May 13, 2011
Fred Yearian
Boss Master
Level 3:
Answers
5603
Questions
Helped
2247551
Points
16162
Moost of these will only use a max card of 2Gb. There are some conversion programs. There was a lot of discussion at one time on Vsplanet dot com about these units if the site is still active.
Boss br-600 unsupported card
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
1helpful
I'm trying to buy a bigger memory card for the BOSS Micro BR, larger than the 128 mb. I purchased a "SD" 2 Gb card but always says "Unsupported format". is there a certain size or brand...
I believe this takes a MAXIMUM of a 1Gb card... Lot's of luck trying to find one of those these days!
You can try formatting it with the Micro BR but it probably won't do it.
Getting unsupported format on my micro br
Format the media using the recorder. There are some special programs around to convert the data. These proprietary formats are a problem when not formatted on the Micro BR itself.
I downloaded a song on my laptop, saved it to my sd card, put the card in the mirco br, but it doesnt show up??
It is in different format. You must go through a format convertor to make it compatible. Use Google to find Micro BR format convertors.
Downloaded version 2 to my br900cd now one of my flashcards that i had several songs on will not load message saying unsupported card
Don't you just hate these incompatibility issues?
Try the VSPLANET.com site where a lot is discussed about the Roland (Boss) recorders.
Sounds like a version compatibility problem.
Check with the folks over at VSPLANET.com where Roland digital recorders are discussed in the forums.
16helpful
2answers
"Card Full" error when the card is in fact empty...
I had the same issue, and ended up solving it after trying many different things. So first you put the card in your reader, right click, and hit "format...". It should ask you if it's ok to erase everything. Say yes.
Then put the card in the recorder, and it should say "Unformatted". Hit Utility and TR4 to Initialize. That should do the trick. Hope that helps!
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
