Several things to do: Plugging into the tape type inputs... say the 7/8 channel.
The little button below the set you plug into needs to be pushed to the down position. This selects the "B" set which are the RCA jacks.
Below the set you are plugged into. Turn up the top knob "Gain" until the "clip" LED just isn't quite flashing.
At the bottom of that same column Turn up the "level" as needed for the mix.
Then of course, advance the Master level as needed.
