2005 Honda Civic Logo
Posted on May 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or alarm?
Anonymous
Level 3:
  • Master 510 Answers
  • Posted on May 13, 2011
Anonymous
Master
Level 3:
Answers
510
Questions
0
Helped
384358
Points
1812
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
Immobiliser on honda civic 1996 doesnt work
Just get a different immoblizer install or take it right out instead of fulling around with it,
Flat battery key wont work locked out of my civic
If you don't have a key to unlock the door, you will probably have to have a locksmith get in or go to the dealer and have a new key made.
1helpful
2003 Honda civic alarm fob not unlocking car
Usually when you change a Fob battery you have to re-sync it to the car. Some cars have you lock and unlock the drivers door with the key.
Should be in your owner's manual.
The battery for my honda civic type - r went flat and when i put a new one in the alarm went off so i tryed to sync the keys to the car ( it tuns the alarm off and u can drive it but once u lock the doors...
Here are the options for disarming a factory alarm while it's going off:
1. Close all doors, trunk and hood. Alarm will stop after preset time.
2. Hit the unlock or lock button on the remote. (One of the 2 works... I just don't remember which.)
3. With all doors, trunk and hood close, insert the key in the driver's door and unlock/lock the doors manually.
Also, is it a factory security system? Is it a honda key fob? or a remote start system perhaps?
My alarm keeps goin off when i connect my battery on my corsa sport r reg
When yo disconnected the battery, it set the alarm. If you have a remote control key fob, go ahead and connect the battery. Using the key fob, turn the alarm on then off. If that doesn't work, use the ignition key in the drivers door lock, turn the key all the way to the left, then all the way to the right. This should shut the alarm off. If it still won't go off, look for a reset button under the driver side dash. Hold the button down until the alarm beeps once. If you can't find a reset button, and nothing you've tried will turn the alarm off, you will need to seek help from a dealership, or a shop that specializes in alarms.
Car alarm honda civiv type r
im with you i think key and fob !
1helpful
2005 honda civic ex (alarm goes off)
Hi Nina, what year is the car? we need to Identify if this is a factory fit or a retrofit alarm. Once I know that I may be able to help.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
