Singer 1120 Mechanical Sewing Machine Logo
Posted on May 13, 2011
Have old, (but good) 6217 c model. Cannot attach button hole foot, seems too long for the shank that you attach feet to. Only one hole in the shank and the shank on the button hole foot is too long for the screw hole in the attachment shank.
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on May 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
7201
Points
42
You are trying to attach a long shank foot to a short shank machine. Look for a short shank foot on either Ebay. You may also find it included within a "tin" of accessories at a local thrift shop. If neither of these options work for you check with your local fabric store or sewing machine repair shop for the correct button foot.
I have a more 1787180 Kenmore model and want a freemotion foot
The Kenmore 158.1787180 uses a low shank sewing machine foot. See some of the parts here: https://www.sewingpartsonline.com/kenmore-158-1787180-sewing-machine-parts.aspx?index=1 . As long as you get the correct shank height, most presser feet are universal. You can also get the snap-on feet and an appropriate shank to snap-on foot universal adapter. (Some button-hole feet need to plug into the sewing machine, for example.)
It can be hard to measure the shank on presser feet. You need the distance from the bottom of the foot to the bottom of the screw opening. See https://www.anniescatalog.com/pages/which_foot.html . I've found calipers are better then most tape measures for this. (If you measure to the absolute center of the screw, then you add 1/4".)
I hope this helps.
Is Bernina 450 a low shank machine or a high shank
Using Standard Low Shank Feet
There are 2 different adaptors available that will allow you to use standard low shank presser feet and snap on feet. Some people prefer this method instead of forking out $20-$50 per Bernina presser foot. If you have other sewing machines, it may make sense financially to invest in more low shank or snap on feet that you can take from machine to machine. If you decide to go this route, I just want to remind you that if your machine uses the presser feet with the sensors, these adaptors will not trigger those sensors.
Use Snap On Presser Feet
This snap on presser foot adaptor is available in both old style and new style. When ordering your generic snap on feet for this shank adaptor, be sure you're ordering the correct maximum stitch width that your machine has. This is a very convenient shank since you're able to quickly switch between many different feet without having to remove the shank.
Use Low Shank Presser Feet
Chances are if you sew, you have low shank feet laying around (or 40). This low shank presser foot adaptor is available in both old styleand new style. Simply install this shank like a normal Bernina foot, and then screw your low shank foot to the shank. If you install a low shank foot onto this adaptor, be sure to test with a wide zig zag to make sure the installed foot is wide enough to accommodate your machines maximum stitch width.
2answers
Is bernina 930 a low shank or high shank machine
Bernina has feet that are specific to their machines only. They have old and new style feet depending when the machine was made. You cannot put generic low, high, slant or snap on feet on a Bernina sewing machine.
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
http://www.ebay.com/itm/Adapter-Low-Shank-Feet-Foot-Bernina-500-1630-Old-Style-/380397208368
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
http://www.ebay.com/itm/BERNINA-ORIGINAL-20-SATIN-DECORATIVE-STITCH-FOOT-OLD-STYLE-830-1530-930-etc-/132055492681
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
http://www.ebay.com/itm/20-Feet-Set-for-Bernina-Sewing-Machine-Old-Style-530-1630-Models-/381790565625
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
1helpful
2answers
Need to find Zipper foot for my mom. She is 80 years old and loves her machine
try http://www.sewingmachinesplus.com/sewing-feet.php they have a huge variety of machines and accessories and should be able to match one for you
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
I am having a difficult time finding pressure feet for my Singer 4562 such as button hole, button sewing, embroidery, walking foot, quilting foot, etc.
You should be able to find presser feet for your machine as long as you know what type of shank your machine takes. Just confirm that whatever you choose will fit a Singer model 4562. You can even purchase a snap-on shank adapter and then purchase snap-on feet for your machine.
Product Quick Search 318 335 4567
Sewing Parts Online Search
http://parts.singerco.com/CPpartCharts/4_4999 (look for 4562)
Quilting and patchwork foot with attached shank
Probably, but since we don't know the model, we can't help you much.
You can search the internet for your make and model machine and search for a 1/4" presser foot. You'll most likely find one piece presser feet or even snap-on feet where you purchase the shank adapter and then separate presser feet that attach to the shank.
You can also check with your local Pfaff dealer.
I cant get presser feet to snap on to my low shank feet holder
Are you making sure the little metal bar is lined up with the little snap on grip?
HI, I have an old Elna Stella, bought in Australia in 1983. The shank that holds the presser foot onto the column keeps slipping forward. This causes the needle to strike the presser foot at the back edge...
Are all your sewing feet in one piece that screw on? I'm struggling understanding what your foot is actually doing Lindy; is it because the nut loosens up quickly? or is it possible that the foot you are using is not an Elna foot?
Elna later changed to "Low Shank" clip on feet with the Air Electronic range and these should be interchangeable with your Stella. I found a good website for this, www.sewingpartsonline.com and he has the "Pressure Foot Shank" which is the later swissmade shank for the swiss made Elnas. I couldn't see a replacement screw to hold on the feet though but a sewing machine dealer might be able to track one down. Or try Ebay, still some swiss Elna stuff out there.
good luck
Carolyn
I have lost the zipper foot and button hole foot, and I have a wedding dress and 5 bridesmaid dresses to make....have tried everywhere, where can I get new feet????
I've found replacement feet at Jo-ann's and Hancock's. The most important thing to know is whether your machine is a low shank, high shank, or slant shank. Other than that, or perhaps (depending on where you live) a a full-service sewing machine retailer or maybe a quilt shop, you'll need to order them online. Try http://sewingpartsonline.com/ they have a qood selection of pressure feet. I've found that pretty much, within the low shank, high shank, and slant shank categories, feet are pretty much interchangeable.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
