Make sure you are using BALANCED audio line to the speaker AND your mixer is powered from the SAME receptacle as this speaker. One MAY have to run an extension cord back to the mixer and othe equipment, but this must be done to reduce noise and also for equipment safety. Multiple recepatacles in a building have grounding issues that can generate noise or worse damage equipment due to ground loops. If you DJ mixer does NOT have balanced outputs, use DI boxes so you can use balanced lines to your speakers. Your cables will either be XLR or 1/4 inch TRS types, not just TS type.
