Just getting back to your earlier email. I am sorry but I had a question about my Reebok Fit Watch. How does the ConAir site help with this?Just getting back to your earlier email. I am sorry but I had a question about my Reebok Fit Watch. How does the ConAir site help with this?
You can't post conmments that contain an email address.
Turn on the Calculator: Press the "ON" or "AC" button to turn on the calculator.
Enter Time Set Mode: To access the time settings, you may need to press a specific button or key combination. Look for a button labeled "TIME SET," "TIME," "SET," or similar. Press this button to enter the time set mode.
Set the Date and Time: Once you are in the time set mode, you can use the number keys and other function keys to enter the date and time information. Typically, you'll enter the date as month/day/year (e.g., MM/DD/YYYY) and the time as hours:minutes (e.g., HH:MM). Use the "AM/PM" or "24HR" key to toggle between the 12-hour and 24-hour time formats.
Confirm Settings: After entering the date and time, press the "SET" or "ENTER" button to confirm your settings.
Exit Time Set Mode: Press the "TIME SET," "TIME," "SET," or another designated button to exit the time set mode and return to regular calculator mode.
How to Set the Time & Date for a MP25DV Canon Calendar & Clock Printing Calculator
The steps listed in the Calculator Instruction Manual for the Canon MP25DV Calculator did not work. The correct steps for setting the time and date on this calculator are listed below:
1. Press the time/calendar button one to select the date mode. The display should show the month-day-year. 2. Hold down the = button until the month start flashing. 3. Use the number keys to enter the current date, month and year. Example 07-22-2021 4. Press the = key to set the current date. 5. Press the CE/C key to return back to the calculator mode. 6. Press the time/calendar button twice to select the time mode. The display show the hour-minute-seconds & time of day. Example 02-01-14 A 7. Hold down the = button until the hour start flashing. 8. Use the number keys to enter the current time. 9. Press the X button for (A) a.m. or (P) for p.m. 10. Press the = key to set the current time. 11. Press the CE/C key to return back to the calculator mode. 12. To check the current date and time on your calculator, press the calendar/time button once for date and twice for time.
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Below are the steps to assist you in setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are on the faceplate above the respective key. Position the calculator so that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press the AM/PM accordingly.
4. Firmly press and release the TIME SET key. The first digit should stop blinking and the time is then set. The seconds will again be displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To return to either the TIME or DATE, press the CALENDAR/CLOCK key to toggle between them.
Setting the date:
Setting the time:
Hold down the time set key (M+ key) for 3 seconds. Then hit the date/time key. Enter in the correct date. Hit the time set key again to set. To set the time hit the date/time key twice to bring up the time.
Hope this helps.
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
I found this and it seems to work
Solution #2posted on Nov 17, 2006
By greeneyes
Rank: Guru
Rating: 94.81%, 27 votes
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button.
Then, press the calendar, clock key.
next, press the equal sign key until the date is flashing
type in the date using 11172006.
press the equal sign again and the date is set.
Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set.
to display the date and time when not using the calculator, press the calculator, clock key 2x's.
to go to compute mode press the red CE/C button.
