SOURCE: Continuous Dehumidifier Operation issue
Unfortunately, I haven't been able to get the water from the dehumidifier to drain out the hose. It always empties into the bucket, which means I have to empty it daily.
SOURCE: I purchased a new Frigidaire dehumidifier and the
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
SOURCE: My Frigidaire dehumidifier model FDL70S1has
All most all dehumidifiers have a defrost cycle to take care of this problem. However, yours is either not working or the air intake filter is clogged, which makes the unit strain to keep up. Turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to remove the filter. Allow the unit to thaw while it's unplugged. Once it's completely thawed, plug the unit back in, turn the Master ON/OFF Switch to ON and set your controls as you normally do. Within in an hour or two, you will know if this solved the problem. Also, keep in mind, dehumidifiers are designed only to work in temperatures above 41 degrees. If it's below that where you have the unit, that will cause it to freeze up.
With all that said, what you're seeing as the Error Code is in fact, AS (the 'S' looks a lot like a 5 on the LED screen) It indicates a Sensor Failure. In your case, it's more than likely the Defrost Cycle Sensor. The Owners Manual says "Contact your local Authorized Frigidaire Service Center, if this happens. I'm hoping that cleaning the filter (if needed) and allowing the unit to reset itself (while it's OFF & Unplugged) will solve the problem. But, it may only be a band aide fix.
Hope this helped you.
SOURCE: I have had the Frigidaire
The faulty float valve is almost always the problem, based on what you described. It is a replaceable part, but you may have to but the entire bucket assembly. Generally, they run around $50.00. However, not all parts are still available for that model, even though it's only 4 years old.
If you want pursue finding the float valve or a new bucket assembly, the best place I've found is online is Appliance Factory Parts http://www.appliancefactoryparts.com/search/index.php they carry parts for just about any appliance you can think of.
Or Frigidaire Parts Select
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Frigidaire&Term=frigidaire&gclid=CIfU4u28vqkCFcPd4Aod6CC5hQ
I hope this helped you. Please let me know. Thanks.
SOURCE: just purchased a Frigidaire 50
There may be a clog in the hose, which should be no longer than 5 feet or there is a clog inside the hose connection. Possibly some packing debris. To solve the problem, do the following:
Turn the unit OFF and unplug it.
Disconnect the hose from the hose connection. Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow. Reconnect the hose to the hose connection, plug the unit in and turn the Master
ON/OFF Switch to ON. Set the humidity extraction level to 35% or
Maximum if you have a manually controlled unit. Allow the unit to run for an hour,
while you monitor it for any leakage or drainage into the bucket.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
If it still doesn't drain thru the hose. Remove the water bucket and check the top for a float valve. It may be stuck in the UP position. If it is, jiggle it to make it return to the down position.
I hope this helped you troubleshoot and solve the problem.
