Have you had any luck with your Technics piano? I've got the same piano and Mine does not work either. No lights on the control panel, only red power light comes on. Does yours have any led lights besides the power light that come on? I've investigated and I have learned a lot from this piano. 4 main boards. Im pretty sure I've got it down to one board. Interested in selling me any boards from your Piano??
i guess the switch is broken - if you are not experienced fixing those problems better bring it to a shop and tell them about the problem - i guess they will be able to fix it easily
Since the PA clip is not lit, the problem seems to be up front...
First thing is to look for a bad cable as a broken ground could be putting hum at a clipping level. First thing, test this by unplugging all inputs. If the clipping light goes out, then you have bad cables or a ground loop.
Try sending a line level signal into "Effects return" to test if the power amps are OK.
If the clip light is still on, turn all gain controls down to minimum. If light is still on then take unit for servicing.
Disconnect the speaker wiring and speaker on the bad channel. Turn the level control(s) all the way counterclockwise and turn the amp on. If your DDT (limiting) light remains lit, it's time for a visit to your nearest certified Peavey service center....G.
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
