Sprint PCS Vision A640 by Samsung(r) Cellular Phone Logo
Posted on May 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is T-coilon theSamsung T255G phone? - Sprint PCS Vision A640 by Samsung(r) Cellular Phone
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on May 15, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
7409
Points
147
T-coil mode is a mode used to link up the phone with a hearing aid.
1helpful
What is the clearance between flywheel and ignition coilon victa tornado tts2226ac
.007 inch to .012 inch If no spark be sure the key - crankshaft to flywheel is not sheared. This will cause out of time fire.
Feb 18, 2017 • Garden
Unlock t255g
You can get the unlock code for your Samsung SGH-T255G phone from ClassicUnlocking.com and unlock your phone from Network lock easily.
Need unlock for samsung tracfone SGH-t255G
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
2helpful
How do I get a copy of theSamsung a516 Cell Phone User's Manual?
http://www.comparecellular.com/images/phones/userguide1082.pdf This PDF file is a user guide for the Samsung a516
How do I adjust the volume control on my samsung t255g cell phone?
Main Menu Settings Sound Profile Find your selection (example "Normal") Hit the "OK" button Then there are three categories to choose from on this next screen (call, message, phone) use the left/right keys around the "OK" button to choose which one you want. Use the up/down keys around the "OK" button to modify the selection For example, use the right key to go to "Phone" and then the down key to make adjustments. Keep hitting the down key until the writing in the yellow menu says "volume" Hit "OK" From there you can adjust the volume
If you want to adjust call volume, highlight "call" with the left/right keys Use the down key to go in the yellow area and keep pressing the down key until you see "ringtone volume" then hit "OK" and it gives you an option to adjust ringtone volume
Hope this helps!
Feb 27, 2011 • Cell Phones
1helpful
Samsung T255G PUK Code?
Puk code is given by the service provider
contact your service provider
Jan 05, 2011 • Cell Phones
2helpful
NEED A PUK CODE FOR A SGH-T255G
The PUC (PUK) is a SIM-specific code assigned by the service provider. It is near-impossible to guess and enter it; thus, if you do not know your PUC (PUK) and are prompted for it, you should get it from your service provider.
I have a samsung sgh-t255g tracfone and i am not able to access because it locked when i turn it on it says PHONE LOCK and then sos calls are allowed only
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Dec 07, 2010 • Cell Phones
Top Sprint Cell Phones Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
