Kenmore Top Freezer Refrigerator Logo
Andrew Przybysz Posted on May 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
402
Points
Ice maker stop working
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on May 15, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835263
Points
101584
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Ken more refrigerator has no ice maker but water is pooling under the crisper drawers. Model c21tfa95
Check the drain channel at the rear of the fridge just above the crisper drawers and blow through the drain hole with a drinking straw to clear it.
There is water leaking down from the ceiling of the refrigartor and pooling in crisper drawer. It is a top freezer model
The drain is clogged that goes down to the bottom of the fridge during defrost. What's the model number?
1helpful
Danby Designer All Fridge (no freezer) Model # DFF1776WE Water pooling underneath crisper drawers. Very full every couple of days. Then it leaks out the bottom door hinge. Not sure if drainholes are the...
Yes it is located in the refrigerator on the bottom in the back. I assume you know how to clear it, Hot water plus towel to soak up excess water should take several tries of very hot water until it clears. Good luck
Fridge is leaking water from top of fridge and water in bottom of fridge
The defrost drain hole is plugged. you must open that and then the water from defrosting will not pool up below the crispers in the bottom of the frig. Generic ice box Manual and more Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5helpful
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
1helpful
Water in bottom of fridge and in crisper drawers
the defrost drain in the freezer is clogged with ice.
empty the food from the freezer, and put through a defrost. you might have to help the fridge defrost with a hair dryer. you may also have to remove the rear panel (inside the freezer) or pending on the model to bottom panel of the freezer.. (usually held in by 1/4" hex screws.)
melt all the ice, and be sure that the drain is clear, and it should work.
11helpful
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
1helpful
2answers
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
