SOURCE: MAGNAVOX STEREO MODEL# FW3863...WILL NT RECOGNIZE
Most likely, you laser, Quadrant detector is faulty, if you replace that laser head assembly, most likely that will fix it. Anyways there is NO other way to troubleshoot... but for swapping out, for "Know Good". You need to get this unit looked at by a professional, ask for a "Quote" before proceeding with any repair.
SOURCE: Philips mc235B/37 CD player no longers plays
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
SOURCE: My Magnavox MDV 2100 is
Unplug the unit for few minutes, say 15 minutes and then plug it back and see if that helps. If that does not resolve the problem, this would confirm an internal problem and needs repair.
This is a common problem on these sets.What you might want to try is to run a CD player cleaner disc through
it; if it is a problem caused by a dirty head or pickup, this sometimes
helps. CD cleaner discs are available at Wal-mart or any electronics
store.If this does not help, the CD player will need to be removed from the car and sent in to a service center to be repaired.
If there is any disc that remains stuck, there
is a pinhole in the front of the DVD faceplate, use a paperclip --
insert and push in , with little force, -- bay door will open ( This option is applicable for most of the models ).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
