SOURCE: white spots come up on LG Plsama TV screen
i had and are having the same problem. first fix was new boards.. now i will be having it done again.. the first time the cost would of been around 850.00.. warranty thank you very much...now it will be the extended warranty i'm using...thank you again.. was told its a known issue witht he lg screens that came out earlier than the others the change out was just last aug or so.. next time it goes the extnded warranty will be a replacement..
SOURCE: i have pink spots on my tv screen. do you know
you most likely have a light engine problem ocouring causing the pink spots
they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
