Refrigerators Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frezzer cold Frige warm - Refrigerators
Anonymous
Level 2:
Guru:
  • Expert 257 Answers
  • Posted on May 17, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
257
Questions
Helped
98704
Points
705
Hello LtCent,
I understand that your fridge is warm and your Feezer is cold. I have wrote a tip just about this porblem with refridgerators that will help you to fix the problem that you are having. Below is a link to the tip that you will need to follow in order to repair your unit.
Freezer Cold, Fridge Warm
Thank you for choosing FixYa.com
Justinbur167
Frige cool freezer warm
IS the compressor running and is it hot?
Hi we have a frige frezzer which is 6x3ft about 10 years old and its not frezzing or getting cold but the light and fan are still working?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
7helpful
2answers
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Frezzer is working but the fridge is warm
This usually means the evaporator fan has quit. Located in the freezer it circulates cold air into the frige side.
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
3helpful
2answers
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
