Somtimes this f5 occurs due dust or dirt on the optical system mirrors,lens,or ccd. that will eliminate the light density. get the machine perfectly cleaned.
Here is a link to the error codes for your machine. There are several F5 error codes.
F5 E4
Lid not opened between cycles
F5 E3
Lid unlock fault
F5 E2
Lid lock fault
F5 E1
Lid switch fault
The F5 error code indicates that the Central Control Unit (main machine control board) detects a temperature sensor resistance that is out of the normal range. The F5 error is normally caused by a failed NTC temperature sensor.
Hello my friend, it refers to your hardware components. The error is on your hardware system it causes either the hardware itself where it has a error in the area of SECTOR 1019072 where its status is bad format or its the format of one of your system inside your hardware.
