Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time
for water to drain out of the washer. Common causes for this are kinked
drain hose or clothing, like panties or socks, caught in the pump
suction hose. Why, I've even heard of bra wires coming loose and getting stuck
in that hose, collecting all sorts of gookus and pinching off the flow
of water to the pump. Can you imagine? Yea verily, as surely as the
Sacred Suds doth eternally pass my lips, the "LD" error code springs
forth from such anomalies.
Hope helps.
I;ve got a WD8015C washer, when i put the clothes this morning for a normal washing it started to sound like something inside was blocking the water flow with a clinking noise,I tried to empty the water and see if i can open it didn't , stop and locked,is something blocking the water drain or the spin, how can i open it, how can I check inside? there is no water as it was going to spin
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5
minutes to pump out the water to a point where the pressure switch resets. To
solve this problem make sure that the drain filter pump assembly located inside
the bottom front panel is clean and after cleaning if the error returns then
the pressure switch needs to be tested and if bad then it needs replacement.
Please get back to me if you have any other questions.
Kevin
