SHOULD BE PROB WITH THE MEMORY. JUST CLEAN THE MEMORY WITH STUDENT ERASER.
AND ALSO THE BANK WITH BRUSH. IF THIS DOES NOT SOLVE THEN CHANGE THE MEMORY.
need to provide moreinfo. is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot. If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue.
Best to liaise directly with vendor to have the faulty components replaced.
Hi, Disable the ASR auto-reboot
feature from System Management web page. open a case at HP, and run the diagnostic tools from smartstart CD. Kindly let me know.
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
hi h3rcu135,
the problem is not in ur motherboard& not ina ram the problem is that ur motherboard does not support 2gb ram.it will support 1gb of 667 or even more but not 2gb
