Sony Ericsson XPERIA X10 Cell Phone Logo
Posted on Mar 02, 2018
My sony ericsson w715 is facing problem with flight mode. i cant change the profile to normal or silent. and cant make oe receive calls. also the battery is having problem. even it is original set battery, when charged it indicates that 'use sony ericsson battery. please help!!
1 Related Answer
Anonymous
  • 18 Answers
  • Posted on Aug 05, 2009
SOURCE: Sony Ericsson W715 unlock code
I can unlock this same model by ebay & got unlock instructions as free from unlock guide
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
I cant here people who phone me they can here me
I recently had a similar problem. When you call or receive, Dial the number. press send. then press the "back" button, The top right "-". This switches on the internal speaker.
I by mistakely pressed the flight mode button in my w595 now im not able to make calls or send messages..please help!!
Go to MENU--> SETTINGS-->There you will have options to choose profiles.
You can change to the required profile through that.
1helpful
I made the settings as flight mode. now i want to change the settings to dual sim mode for that which key i have to press for my sigmatel S4 model
You have to change the profile to normal or silent to exit the flight mode.
Otherwise restart your phone it will ask you want to exit the flight mode or not.
Thank you using Fixya
Sep 29, 2010 • Cell Phones
How to put a Sony Ericsson K310i in flight mode?
in other sony-ericsson phone's the flight mode is only showed when it's turned on!
in fact when u turn on u're phone it has 2 options( normal start or flight mode)
but it may be disabled to show the flight mode option and u have to enable it first
it's easy u'll find it in main option tab
How do I cancell flight mode on my elm
Goto Menu -> profiles and select General to restore back your mobile to normal mode from flight mode.
You can also try long pressing (press and hold) the # key in your keypad while your mobile is in normal display mode.
I hope this is helpful to you.
Thanks
1helpful
2answers
Its on flight mode and wont change :O
software corrupted is my suspicion, you could flash new software to the phone in 1 of 2 ways:
the first way (which is what i would do but if you do not feel comfortable with then see second option) is to read this tutorial
http://forums.se-nse.net/topic/39748-tutorial-flashing-a2-phones-with-a2uploader/
download the files you will need which i will give you links to (you have to register but free) (files will be in rar so you will need to have winrar)
http://www.iprotebe.cz/sony-ericsson-firmware-c902-cid52-r3bh002-main-section1422.html
http://www.iprotebe.cz/download-C902_R3BH002_FS_WESTERN-EUROPE_RED52.rar-file11820.html
http://www.iprotebe.cz/download-Customize_C902i_Central_Europe.rar-file14716.html
second option is try using sony ericsson update service which you will find on their website along with instructions
How do I switch my flighmode of my Sony next G mobile?
i think u just press the on/off key once to change ur profile and select flight mode, or just change it through ur profile settings. sorry cant be sure as my phone wont charge atm. damn phones
MY PHONE WAS ON NORMAL MODE SETUP, I CHANGED TO FLIGHT MODE HOW C
if its sony ericsson, just restart it then select the normal mode.
I have a sony ericsson w890i and when I recieve a call there is no ringtone. I have tried different ringtones and they all play on the speaker but not when I get a call.I have reset the phone and...
make sure you have the phone set to ring, it could be on silent or vibrate mode, there is also a profile that will not allow you to set ring tone, it'll always be silent, so try a different profile
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
