SOURCE: My boss dd-3 pedal only works with a 9v battery.
You will have to test the adapter with a volt ohm meter to make sure it is putting out the proper voltage. It should be as close to 9 volts as possible. Also make sure that thehole in the plug is negative and the outside is positive. Is it the right adapter? I don't have a schematic for this model but www.schematicheaven.com has one for a DD-2. Hopefully they haven't changed too much. If you decide to repair it yourself, check the adapter first then check for a bad solder joint where the adapter plug is soldered to the circuit board. Hope this helps somewhat.
SOURCE: My boss DD-3 makes a
Check your power source or battery. The sound is probably due to the internal processor recycling due to watchdog timer. If power is OK, then service will be necessary to repair the problem.
