Question about Fisher and Paykel GWL11 Top Load Washer
Replace the control board on our fisher and paykel washer because it would not power on-still not working-it came on for oh 2 seconds and then nothing??????????????
    Master:
  • Fisher and P... Master
  • 738 Answers
Check out the drain pump as it is linked directly to the main board any burning smell or discolouration of the copper windings replace it
Posted on Apr 21, 2018
6ya staff
SOURCE:
Anonymous
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
Ian Greenland
  • 351 Answers
SOURCE: Fisher Paykel Washer Machine
sounds like the main board has died check for water leaks near board or motor/pump.
Posted on Mar 07, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
Anonymous
Thank you, thank you, thank you fanny! That was so easy! I can't believe I just fixed my washer in 5 minutes!
Posted on Jun 26, 2008
Anonymous
  • 145 Answers
SOURCE: Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Posted on Dec 15, 2008
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel washer keeps saying cutoff restart
The power supply is faulty in the motor controller.
Replace motor controller with new/Reconditioned board.
Apr 25, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
How to replace a power module in a washing machine
Motor controller has faulty power supply.
You need to get a new/recondition motor controller board.
Apr 06, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Power cut reme in 8 seconds
Apr 05, 2012 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher Paykel IW709AU wahing machine, it does not drain the water after the washing cycle ends, but a buzzing sound starts from the water pump for about 30 seconds and the power cuts out. the...
If you wired the pump directly with a lead and 230V supply and it works ok, then doesn't work when powered by the control board, I would say that there is a problem with the control board not supplying a full 230V to the pump.
Dec 04, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
How can I find a repair manual for my Fisher paykel GWL11 washer. I want to replace the controller, but owner's manual contains no parts listing or diagrams.
Careful! Fisher Paykel does not warrant their parts for even 1 day! I received a "new" control board from them once which did not work. Their comment to me was " It worked fine when it left here". That was the last F&P repair I ever did.
Apr 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
Machine water pump continously running on power
problem more than likely faulty triac in electronic board solution : replace motor control board
Feb 25, 2010 | Fisher and Paykel Fisher & Paykel Washer
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
674 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
