Take out the memory card and find a friend/library with a laptop or computer with a slot for a memory card. A lot of people don't realize that they have this! On many newer laptops it will be on the front side of the laptop, with a mock card inside to protect the connections. If you can find this slot you will definitely be able to retrieve your photos. Let me know if you need help finding them on the computer once the card is inserted.
Well If the photos you want to retrieve are on the 15Mo of internal memory, there is not much to do here except to see a repair center.
If they are not on the internal memory, open the Battery hatch of your camera, push on the small card that is close to the battery, then take the card out.
Now you can plug this card directly in a card reader.
If you have a laptop you might have a compatible card reader on it, otherwise buy one, it is always usefull.
Retrieving the photo this way on any camera saves battery and is usually faster than when using an USB cable.
Hope this helps
