Hello first of all
well i am sorry a mechanic cant figure this out its really sad. ok so your problem is your either one of two things but most likely the first one i list.
1. camshaft postion sensor
2. crankshaft postion sensor
Now that being said it most likely the camshaft sensor the reason i say that is when a crankshaft postion sensor is bad the car has very hard starts and most of the time no start issues. When a camshaft postion sensor is bad the car cuts off whil driving and can be hard to start up again.
So that being said they are both pretty cheap parts i would go ahead and replace them both and i would bet my 5 years as ford mechanic that solves your issue.
The crank postion sensor is located behind the harmonic balancer pully or right beside it here is a picture from autozone.com and description.
The crankshaft position sensor identifies position of the crankshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM).
When not replaced, vehicle could experience no- or hard start, long crank time, misfire, lack of power, excessive hydrocarbons in oil, spark plug fouling, catalytic converter failure, poor fuel economy, CEL/MIL illumination or intermittent shutdown.
Designed to meet or exceed OE specifications in form, fit and function.
Global coverage for import and/or domestic applications.And the camshaft sensor picture and info from autozone.com below.
The camshaft position sensor identifies position of the camshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM).
Global coverage for import and/or domestic applications.The crankshaft postion sensor is 22.99 and the cam is 19.99 so 50.00 bucks and about hours time should have you up and running.
PS if this helps please 4 thumbs up it helps me continue to help on here thanks
