Question about Nokia 5130 Cellular Phone
My nokia 5130 charging slot does no more 'hold' the charger. I could not charge the battery. Is there any thing I can do? I recently have a previous nokia 5130 phone with the same problem exchanged for this new phone as part of the warranty agreement. What can I do now? How can I charge it without using the phone's charging slot?
    New Friend:
  • 60 Answers
Here in the philippines, we have a "universal charger" where in you can take out the battery and put it on the universal charger and plug it to the outlet. it's best for your problem. however, if the said exchange that you have said here is part of a warranty then you still had the same problem with the same particular phone, i think you better go to the store where you purchased that phone and talk to them regarding the same old problem. and ask them if they can exchange a different unit for you because tell them that you are not satisfied with the performance of that unreliable and not so durable gadget and its accessories. make a deal with them. convince them. don't let them manipulate you to just accept something that is really not acceptable.
Posted on May 19, 2011
    New Friend:
Recently my phone it fall in to water.bt after that i repaired it.nw phn it is working.bt i cant charge my phone.the socket for charging,it is not accepting non of chargers.so i charged my baterry by using another phone and used it.bt after one day it is showing me "baterry low",eventhough i didn't use music player,no long duration phone calls...still it will show baterry low...plz help me
Posted on Jul 29, 2011
Nokia 5130 show battery charging but battery not save power
i think u should switch off your phone and it will charge smoothly till it full
Jun 19, 2012 | Nokia 5130 Cellular Phone
My nokia 5130c-2 starts charging automatically when i put in the battery without connecting the charger, then the battery discharges in a few hours..... pls help me.
There might be some battery issue you need to replace this battery to another one and please don't left your mobile while you are charging battery cells going to dead if its over charge and you will going to lose your battery and mobile as well Laptop Rental Laptop Hire in UK Wales Ireland and Scotland Hire Laptops
Oct 23, 2017 | Nokia 5130 Cellular Phone
Suddenly off and can't on
Hello.First of all insert another battery and try,secondly insert charger,If your phone indicates charging or still not power on contact mobile repairing shop to examine.Thanks for visiting fixya
Mar 28, 2012 | Nokia 5130 Cellular Phone
Nokia 5130c-2 always charging but when i remove charger battery is low give me solution
Hello.
these symptoms means that a new battery is required.
the phone's battery is exhausted after a long time of use, replace the battery and the problem is solved.
Best Regards.
Jun 03, 2011 | Nokia 5130 Cellular Phone
When I swiched on my mob 5130 c2 it does for seconds and swiched off by itself,but it's battry is very well charched
hi, at times battery will indicate well charged but they are not CHARGED... my advice is you try another battery and see if it will continue like that...but make sure the battery you will be trying is the original nokia battery, because if you still you use a fake battery, it will serve you for awhile before it will start given you problems.
Also, it could be that the charger is faulty, so try using another charger recommended by nokia.
cheers.
May 18, 2010 | Nokia 5130 Cellular Phone
I have a Nokia E71 and the charging problem. When i plugged in the charger to the handset and it doesn't chage but if i either hold it still or standing the phone up at certain position or even push in the...
Have you checked the mouth of your charger? Because your charger mouth might have loose contact internally and you not knowing. But to confirm this, you have to borrow the type of your charger from a friend and test if your phone will do the same thing. And if this does not solve the problem, try loosing the phone with a phone screw driver, check if the charging port is contact the phone board well and if this did not still solve the problem, then you will have to completely change your phone charging.
Best wishes.
Nov 23, 2009 | Nokia E71 Smartphone
Charging
Then there is a problem in the charger socket. Try a different charger from a friend to eliminate the charger. Does your charger work elsewhere?
Aug 14, 2009 | Nokia 6120 classic Cellular Phone
Charging problem nokia 1110
If the phone is not charging or charging is irregular, then problem is either battery , charger socket on phone, or charger itself.
If it does not charge at all, then it is either the battery or the charger.
If it does not hold charge then it is the battery.
If charging is erratical then it is either the charger connector/socket, or the ac charger.
The best thing to do is going to a phone shop, having the charger and the battery checked by the guys at the shop and replacing either the battery or the phone charger.
Mar 04, 2009 | Nokia 1600 Cellular Phone
Nokia 5130 Cellular Phone Logo
193 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
