SOURCE: gas/oil ratio for a Homlite yard broom UT 08026H blower
It's 40:1 but there are oil mixes out there now that you can buy that you mix with one gallon of gas and then it is safe for all 2-cycle engines...a real plus if you own multiple units with different mix ratios.
SOURCE: Need to know the oil and gas mixture for a
The manual probably says 40:1 (3.2oz.oil to 1 gal gas) but if you use a good modern 2 cycle oil,50:1(2.6oz .oil to 1 gal gas) will suffice.
SOURCE: I have a Homelite YARD BROOM II 170 mph
I usually mix at 50:1 useing klotz two stroke oil,or 44:1,klotz is high performance zynthetic oil,also has nice sweet smell when running,keeps the neighbors from complaints on bad smell.
