Right-click the desktop and select Personalization then click Sounds and change the Sound Scheme to non,that is for windows 7.
For XP Go to Start / Settings / Control Panel and then select "Sounds and Audio Devices"
Now click on the "Sounds" tab as shown and select the "Start Windows" sound also as shown.
Where it says "Windows XP Start up" change this to "None" and you will be OK
1. Click Start, click Control Panel, click
Hardware and Sound, and then click Sound.
2. In the Sound window click on the
Sounds (tab).
3. You will see a box with a list of items one being
Asterisk.
4. Click on Asterisk, or any item in that box, and then click
Test.
5. You should hear audio coming from your system.
6. If the clip was not long enough select another item, and then click
Test.
7. Determine whether or not the distorted audio is present.
Configure the speakers
2. In the Sound window right-click your
Speakers and select Configure Speakers.
3. Follow the on-screen setup, and
Test the available configurations.
4. Identify whether or not one configuration appears to have less of an "echo" than others.
5. If the issue is resolved by modifying the configuration then you do not need to do anything further.
These fixes only work for windows and not any third party software.So if you have a sound card,you will have to use the app for it.
