Kyocera Mita KYOCERA/MITA - KM-C3130 Printer Logo
Posted on May 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was on-line yesterday and the terch had me try making changes to clear Imaging Units Needs Replaced - Now I Have An Error Code C12C0
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on May 20, 2011
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191016
Points
2336
This is a hard disk error. When we were troubleshooting yesterday you said you were going to try and disconnect some sensors to by-pass the problem with the Image Units. Did you put them all back? This hard disk error states that it can not communicate with the built-in hard disk.
Jim
Preston Computer Services
www.prestoncomputerservice.com
3answers
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
2answers
1helpful
Samsung scx6555n showing error #31-007
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Fittef what I pressume to be 2 new imaging units to my Bizhub C350 and a malfunction code has appeared C-001A can you tell me what the problem could be?
Sounds like one of the units may be bad as the C001A code means that the Color Imaging Unit drive motor is not turning. It would make sense that if you got this code immediately after changing an imaging unit, that if one was locked up it is now keeping the motor from turning and thus generating the code. In any case the C001A code means the color imaging unit drive motor is not turning.
Good Luck and Thank You for using Fixya.
WheatlandServices
3helpful
Error code C0F32
This error means Imaging Unit ATDC (automatic toner density control) failure. Open and close the right side door where the imaging unit is. If the code comes back you are going to need Imaging Unit service or possible Imaging Unit replacement. The best option and the cheapest is to locate a new imaging unit and replace it yourself. These units are very easy to change and similar to replaceing a toner cartridge in any laser printer. Just do a search for Di200 Imaging Unit.
2answers
Cyan Imaging Unit Failure, U28 Error Code
the only thing I can suggest is to check the contacts that the imaging unit goes into, and i can also be the imaging unit itself. If i am not mistaken, you should be able to swap imaging units from another color just to see if the error goes away. But if this does not help, you will need to get it serviced. we have fixed these before, and its not a quick fix.
Error light
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
2answers
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
