As long as you have a memory stick large enough to hold the size of a movie, the answer is yes. http://listoffreeware.com/list-best-free-media-players/
Remember the player you select must be able to play the type of Movie that you downloaded to the USB Stick.
If you have a usb input and the set has the correct codecs built in, you will be able to watch a movie. May not work with all files. The usb input on a dvd blue ray will usually work with everything however.
Without hacking your wii it isn't possiblle from pendrive, but if you put movie ,converted according to this guide, on SD card, you should be able to watch it in Photo Channel
Are the movies inthe correct format for the player? If it does not register the USB drive, try it without a cable if one is used, and make sure contacts are clean. if it still does not register, the port cotroller may be dead.
usb is an input on on a computer and what u stick in that is a flash drive now a flash drive just holds data its like a memory card. when u stick that in the computer it reads what ever is on that flash drive movies are not played on a usb they are played on the computer which would be by windows media player. thats what always the movie to play. usb is only to transfer data and safe data from one place to another.
the PlayStation 3 can read just about any usb memory stick and play can movies from them, since a usb's bandwidth is significantly lower then the ps3 hard drive it's recommend to copy the movie to the ps3's hard drive.
also it matters how the movie was converted. some converted movies wont play on the ps3 no matter what codec your using to encode the movie with.
1.When you finis making it convert it to MP4 file because MP4 files can only be read an the PSP. 2.when u finish convert it put it in the video and done. 3.Then unplug the usb and then go to your MY VIDEOS and there u can now watch it.
