SOURCE: manual for a microscope
Try Ebay--may have to buy the micro aswell but it won't cost much,have you tried the Tasco website in case a free d'load is avail?-kind regards martin r
SOURCE: I picked up a Bushnell 1200 power microscope at a
You will need to focus in on the slide. There should be 2 1" diameter knobs on either side of the stand, and just to the rear. Those knobs control the height of the stage (where you slide sits). Slowly raise or lower while looking into the eyepiece. At some point something should be see, if the microscope is working properly.
Sometimes it is easiest to start with the lowest magnification. On the outside of the objective (little lenses hanging down that can be rotated) there should be some numbers written on them (usually 4, 10, 40). Those numbers reference your magnification. If you multiply that number by the eyepiece (10) magnification, you will get your total magnification, so start out with your 4x. It will give you the largest field of view, so it is great for finding whatever it is that you are looking for on your slide. It is also the easiest one to get focused. The higher you go in magnification, the smaller the field of view, thereby the more difficult it is focus in on your sample.
