Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 19.5 HP Craftsman (Briggs and Stratton) Riding Lawn mower. It has a 6 speed transmission (uses a stick and clutch to shift) I was mowing the lawn and came to a stop and then the mower would no longer move. The engine sounds fine, the mowing deck engages but there is no power going to the wheels. I looked under the frame and it appears that one of the belts (that goes to the rear end of the tractor) may have come loose. I am wondering what is the best way to put the belt back on? Is it ok to tip the tractor on its side or should i jack it up? Is this one belt likely the cause of my problem? Do you think because the belt came off there could be another issue I should address?
  • Craftsman Master
  • 819 Answers
Yes, You should also check for idler pulley to make sure bearings are not froze also check other pulley bearings and alignment. If you have any doubt replace as you don’t want to revisit this problem if you don’t have to.
Posted on Dec 13, 2017
    Master:
  • Craftsman Master
  • 653 Answers
I would suspect the issue you are having is the belt. I would raise the front of the tractor not tip it on its side. The belt is pretty straightforward on install.
5 Suggested Answers
Anonymous
  • 53 Answers
SOURCE: I have a 2003/4 craftsman riding mower, 23 hp
sounds like the stator under the flywheel is bad that is what charges the battery
Posted on Jun 11, 2009
wadembly
Wade Mobley
  • 513 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
Anonymous
  • 11 Answers
SOURCE: How do I clean the flywheel on my Craftsman/
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Posted on Aug 03, 2009
Anonymous
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
Anonymous
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
The mower wont engage in gear
@the rear of the tractor bottom left you'll see a metalrod sticking out and if it hasn't come off a decal with a picture of man pushing tractor that's it.
Apr 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
402 people viewed this question
Top Craftsman Garden Experts
john h
rjivaro
Marvin
Marvin
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
