My remote is not a RCR311B, it is a RCR311W, is this still the way to get TV to respond? Thanks.My remote is not a RCR311B, it is a RCR311W, is this still the way to get TV to respond? Thanks.
You can't post conmments that contain an email address.
My remote is a RCR311w not a RCR311B, is there a difference? Tried your solution, No results. ThanksMy remote is a RCR311w not a RCR311B, is there a difference? Tried your solution, No results. Thanks
Hi. Are you wanting a Universal so that you control other components, or do you only need a remote for your RCA TV? If you want to go universal, I have found that Logitech Harmony remotes have never failed me. You can get the replacement remote for that model for around $20 + Shipping.
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
The word from RCA technical support is that the remote for the L32HD31R operates on a different frequency and there is currently NO universal remote on the market that will work with the set. They say that they have plans to market a universal remote and that they are working with other manufactuers of remotes but there is no resolution or time frame available. In short, you will have to use two remotes and keep checking the RCA website for a breakthrough.
I'm not sure that I would have bought the TV if I'd known.
The Model L32HD31R, according to RCA, is not "code compatible". It cannot work with a universal remote, or cable/satellite remote. this is peculiar for a company like RCA, however I just bought the same model from Wal*Mart, and companies build models for certain stores. This one was built on the cheap, and one of the things left out of the mix was the "code compatibility".
