This happened to me when my auto battery went dead. Take the manual key out of the smart key fob and use it ually unlock the door. If car battery is OK otherwise do replace the fob battery.
Can you manually unlock the lock and open the door?? Is it more than one door or just one specific door? If its just one door, yourcactuator inside the door may be bad or you have a wire issue. If its all the doors, more than likely you blew a fuse or a relay(id say fuse)
SOURCE: 2003 Monte Carlo SS, FOBS
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Can't open door on Seqouia 2006
