Televison & Video Logo
Posted on Aug 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No signal on tv
Had power cut. all sockets tripped. Following resetting of trip switches none of the lg tvs in my house of which there are 3 are working.
TV 1 42inc power on but no signal message and no access to freeview. NO info on guide showing.
TVs 2 and 3. No power at all on tvs and fuses checked, batteries on remote controls checked. All fine. One of the 26in tvs has sky. the other is freeview only.
TVs are approx 6 months old.
Phone number required also for lg technical support as having difficulty finding number.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 06, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
835
Points
0
I have 32ins Samsung displaying no satellite signal what is solution?
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Aug 15, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782901
Points
6681
Since the TVs are less then a year old, they're still under manufacturers warranty. LG Contact Information Main support number 1-800-243-0000
Email: support[email protected]
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Roger black AG-W11306 been walking on treadmill for about 20 mins when it cut out and tripped the main power breaker switch cutting out TVs and all electrics in house any ideas
bfe672f8-10b0-4eca-a009-dc9848741c38.gif1) LUBE the treadmills very important with silicones or waxy READ your owner manual
2) Run the software calibration for diagnose and fix it.
3) Measure the input voltage motor
4) measute the output voltage from controller board for input voltage motor.
My fridge is tripping the power out in my house. do i need a new motor?
It might not be the motor, it could even be the door switch, but first unplug the fridge, disconnect the wires from the motor, insulate them, switch on and see if your house power trips out. If the house does not trip out it is the motor. It is still trips out, look at the wires to the switch and the light and also the thermostat. Good luck and remember to unplug the wall socket whenever checking any circuit.
Bissell lift off bagless tripped breaker. Cut
if it overheated, there is a automatic switch in or near the motor that resets automatically...if its cooled and wont start back up??? Then check that your outlet has power to it. if not, reset trhe house breaker and if it does, start hitting garage sales for 5 dollar vacuums....
When i connect the TV the power trips and shuts down, short circuit
This is just a stab in the dark. Have you tryed a power extension lead (the ones you use for cutting the grass) Try this on another socket in your house. This will rule out if its the television or just the double socket behind your telly being faulty.
Hope you get this sorted out
Cheers
Little Dish Fitter
1helpful
2answers
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
MAIN RCD CIRCUIT TRIPPING OUT
it may not be the freezer. ground fault recept. are known to go bad pretty regular. upplug freezer and see if it still trips. It doesn't take much to trip one, so look for something simple
Aug 18, 2008 • Freezers
2answers
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
