Quinny ZAPP Stroller Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a quinny zapp push chair and the release button on the one side does not lock into place. Do they sell these spare parts. or is there a quick fix cheers
Dorel UK
Level 3:
  • Quinny Master 1,637 Answers
  • Posted on May 23, 2011
Dorel UK
Quinny Master
Level 3:
Answers
1637
Questions
0
Helped
453529
Points
2410
Good Evening
Only the number 1 button will stay in - the number 2 button must be held as you're folding/unfolding.
If it is the number 1 button that is no longer staying in, then unfortunately there isn't a quick fix and due to the way it is integrated into the chassis it isn't an item we can send out as a spare part for you to replace yourself.
How old is your Zapp? If it is under 2 years old, please contact your retailer with your proof of purchase for them to make the necessary arrangements to send the chassis back to our engineers to provide full inspection and repair work under the warranty terms and conditions.
On my quinny zapt, I lost the round metal part #1 that holds the bet chair. where can I get repleasement
Replacement recline adaptors for the Quinny Zapp Xtra can be ordered via your local Quinny retailer or direct from the customer service department 01284 413 141 Mon-Fri 8.30-4.30. RRP 25GBP if ordered direct 3.99GBP p+p additional.
QUINNY ZAPP, LEFT SIDE WILL NOT LOCK INTO PLACE WHEN PUT UP THE GREY BUTTON HAS NO PRESSURE TO IT WHEN PUSHED IN IT STAYS IN UNLESS YOU TIP THE WHOLE PUSHCHAIR OVER ON ITS SIDE THEN IT FALL BACK OUT CAN...
Good Morning
This can be fixed by our engineers. If the Zapp is under 2 years old please contact your retailer with your proof of purchase and they can make arrangements for the unit to be sent to our engineers for full inspection and repair work required under the terms and conditions of the 2 year chassis warranty. If it is over 2 years old or you do not have proof of purchase please go to www.quinny.com and select the country you're in, then choose "Contact Us" to write to the customer service department in your country who can advise you how to proceed with getting it repaired.
1helpful
I bought my zap 2007 for my 1st son and this coming 2011 will need maxicosy baby chair for my 2nd son to go on my old quinny. Because the maxicosy 2010. Are the compatible? Old quinny with new maxicosy?
hi
yes they are compatible quinny haven't change any of the connections
have you seen the new quinny zapp xtra seat unit that fits the older zapps
it can be used from birth
http://www.olivers-baby-care.co.uk/quinny-zapp-xtra-seat-unit.html
My quinny zapp pushchair seat has ripped and i need replaysment but cant find any were that sells them please help
Try Dorel UK 01842 763 281 (Mon ? Fri, 8:30 am to 4:30 pm) Sole UK agents/service/repair/spares for Quinny
1helpful
2answers
How do i lock the wheels in place on my Quinny Zapp?
Hi, they have an instruction manual for the Quinny Zapp over at the following link:
http://www.freebabymanuals.com/quinny/prams/Page-2
It explains how to do it.
Hope that helps.
How to remove the maxi cosi seat from the quinny zapp frame
At the bottom of the handle of the carseat, there will be a silver button (both sides). Press these buttons in and the carseat will release.
I hope this helps.
2helpful
The bar in between the handle bars has snapped can
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
Im looking quinny zapp's red coloured break button(a small part )
i have just contacted a shop that sells quinnys and they orderd the same part for me! its costing me £5 for the red break part
2answers
Quinny Zapp Undeployable Frame
You have hopefully sorted this out by now, but I had a similar problem with my Quinny Zapp. I sprayed the button with WD40 (between the button and the surrounding plastic) and this did the trick for mine.
Best wishes
Nerys
2answers
Rear axle and wheels
you have to push the small grey release button up again while the wheel is in. now the only way to do that is to push it from the other side. remove the the cover on the opposite side by removing the phillips screw on the inner of the wheel housing . the cover will pop off as there is a spring underneath it, you will see the grey plastic below. slide in the wheel, push the grey plastic up with a screw driver, make sure the wheel is firmly in place, replace the cap and screw it back in place tight.
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
