The z-sustain board is bad. One of the the heat sinks on the board is cool to the touch. These had LG circuit boards and the number on the sticker, on the board, was a good LG part number. The part numbers were 6871QZH044A.
Do a search on the internet with Google, Yahoo, or Ebay with this part number. The board unplugs and the new one plugs back up. Not an advanced technical repair. Unplug the set and take the back off and match the picture on Ebay with the one in your set. And especially match the part numer.
Since you have some picture the Y-sustain and the buffer boards should be good especially if the fuses on the Y-sustain are still good. The Y-sustain is the larger board to the left looking from the back. Check the fuses on it. The buffer boards are the long two boards to the far left looking from the back of the set. If there is a blown fuse on the Y-sustain you must replace it AND both upper and lower buffer boards as well as the Z-sustain which is the larger board to the far right looking from the back of the set. Be sure to check the fuses in the Y-sustain before installing the Z-sustain. The part numbers should be on each board beginning like 6871...
