Samsung Galaxy Tab Tablet PC Logo
Posted on May 24, 2011
I want to hard reset my galaxy tap. I have a symbol of phone on left then central yellow triangle with ! and computer symbol on right and holding volume button down with power button nothing happens
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
604
Points
How to hard rest Samsung Galaxy Tab Tablet PC
press and hold -sound and power for 5 second you well open recovre mod press hard reset and press the long words and write yes the phone well restart and well pe in factore mod
SHABBIR SHAIKH
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on May 26, 2011
SHABBIR SHAIKH
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
5538
Points
86
THERE IS NO USE OF HARD RESET I THINK THAT MAY BE WRONG WITH UR HANDSET POWER &VOLUME KEY BETTER U GO TO SAMSUNG SERVICE CENTRE
DONT PUT ANY OUT SOURCE IT MAY TEMPER UR WARRENTY
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
I received a gift the I craig 9 inch touch screen tablet model: CMP756 I followed the directions set up when finished shut down when I turned it back on it is stuck on loading screen and won't procced to...
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
Costumer support
Data will be lost so first press the back up option and take a back up into sd card
If/when you're on the Android System Recovery screen release all the keys, and then use theVolume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
5helpful
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
1helpful
Master reset htc phone
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
  1. Back up all necessary data by copying any files you want to save from your phone to your computer.
  2. From the Start screen, swipe left.
  3. Tap Settings.
  4. Tap about.
  5. Tap reset your phone.
  6. Tap yes.
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
  2. With the phone turned off, press and hold the Volume Up and Volume Down keys.
  3. While still pressing the Volume keys, quickly press the Power/Lock key.
  4. When the device displays 'This operation will delete all your personal data, and reset all settings to manufacturer default. Press Vol Down to restore manufacturer default, or press other keys to cancel.', release the Volume keys.
  5. Press the Volume Down key to reset the device.
2helpful
Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
6helpful
3answers
How do I delete all the applications and data on Samsung Galaxy Tab?
Hey there,
In order ot hard reset your Samsung Galaxy Tab you need to perform the following steps: Be aware that this will erase everything!
1. Turn the device off 2. while the device is turned off press and hold the volume up button and the power button 3. release the power button when you see the samsung logo appear. (Do not let go of the volume up button until you see the recovery screen) 4. use the volume button to naviagte through the menu until you find an option titled Wipe data / Factory reset 5. once you fin that option, highlight it and press the home button. 6. press the volume up button to continue
Your galaxy tab will now start the hard reset process, do not touch anything until it is complete
Hope this helps!!
24helpful
2answers
Galaxy p1000 is frozen cant switch off nothing is happening
Hope this helps:
How to Hard Reset Samsung GT-P1000 Galaxy TAB:
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
