Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Dec 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch front load washer...WFMC3200UC...6+ years old...light to medium duty...no problems UNTIL we now have an apparent slow leak into the drum when the washer is completely "at rest". I assume the water mix control valve ?? Is this something a decent do-it-yourself 70 year old can get to and fix?
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Dec 27, 2017
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206158
Points
1556
I would take the water pump ad trip it to clear the rotating shaft of possible cotton threds or other debris stuck in-between the rubber water seals as this can cause a slow dripping of the water as it creeps between the still shaft of the water pump eric
5 Related Answers
A
Anonymous
  • Posted on May 31, 2008
SOURCE: Bosch Maxx WFL 2850 - the drum will not turn around
Check the electronic board for a short.
robb101
  • 6 Answers
  • Posted on Jun 05, 2008
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Anonymous
  • Posted on Aug 20, 2008
SOURCE: Bosch WFMC3200UC
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Anonymous
  • 3 Answers
  • Posted on Sep 15, 2008
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
woobie dog
woobie dog
  • 1273 Answers
  • Posted on Sep 13, 2009
SOURCE: water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Washer wont spin, wash or pump enough water in the machine
This is several issues rolled into one. The clank noise is concerning and the smell could be the heating element for high wash temps. The other thing is the control module could be causing a lot of this. The water valves could be causing the fill issue and the clank could be the pulley on the drum. The bad thing is there are not a lot of parts for that machine as it was 13 years old. The control board is almost 300 dollars. Taking the time to trouble shoot it requires tools and patience . The service manual link is attached. Bosch WFMC3200UC Training Manual
I HAVE A BOSCH FRONT LOAD WASH MACHINE MODEL WFMC3200UC. IT WILL FILL AND THE LIGHT COME ON TO WASH AND THEN IT STARTS PUMPING OUT THE WATER.
B This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
1helpful
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
2helpful
I need a replacement rubber seal for my Boch front laod washer Model# wfmc3200uc/01. I also need the plastic peice that holds this seal in place. I have only had this washer for a little under 1 year is...
It all come in one kit: plastic front cover and boot gasket.
Part # 246270.
Manufacture warranty for Bosch washer 1 year from day of purchase.
For assistance with your Bosch home appliance
or to order spare parts
1-800-944-2904
MON - FRI ~ 5AM - 8PM PST
Also you can buy from here:
http://www.marcone.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
2helpful
2answers
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
2answers
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
