In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
The Canon Color Image RUNNER 3200 machine has two on and off switches. Facing your machine. One is on the right side and the other is on the back left side. Shut machine down. Wait for about 10 min.s turn switch on.
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'. Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected. If the above are set correctly, go to HP's website and download the latest driver for your printer.
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
