Sennheiser Sennhesier MM 100 Bluetooth Stereo Headset Neckband Wearing Style (504111) Logo
Posted on May 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't turn off the Sennheiser MM 100 Bluetooth Stereo Headset. The blue lights are blinking without stop. What to do to turn off the headset?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 17, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3419
Points
A faster solution is to plug in the charger for a second and that will reset the led.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 15, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2929
Points
I had the same problem. (Eventually) I 'un-paired' the headphones from my Mac; left them for an hour - until they went off automatically; then paired them again. It seems to have done the trick.
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sennheiser Master 1,001 Answers
  • Posted on Dec 22, 2016
wwlvictoria
Sennheiser Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603840
Points
6027
Headphone is easy to pair to most Smart Phones and Bluetooth-enabled Tablet.You can wear the earphone while you're running or working out, and do not have to stick your iPhone in pocket.make you enjoy the exercise. Amazon com Bluetooth Headphone Charm sonic Wireless Headphone for Gym...
Anonymous
Level 1:
New Friend:
  • Posted on Jun 18, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2929
Points
Had the same problem. Plugging it into power did the trick for me. I like these headphones but they have a LOT of problems with bluetooth.
2answers
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Great headset till I got an Android - How to connect
To Pair the Sennheiser VMX 100 headset with your cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices (and it should work for Android phones as well), but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
1helpful
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
2helpful
I have a Bluetooth headset VMX 100. I paired it with my iPhone, I can make phones, but I cannot listen to the music from my iPhone, or the VMX100 designed to not to listen any music. Thanks
In order to have music streamed to a bluetooth headset, it must bear A2DP (Avanced Audio Distribution Profile). You see, all stereo bluetooth headsets available on the market do support that profile. Nevertheless, the VMX100 is a monaural headset, thus bearing both HFP (Hands Free Profile) and HSP (HeadSet Profile) only, which are suitable for phone calls only.
Well, depeniding on your phone platform, you might find applications around which route all audio to a monaural bluetooth headset. However, you would, most probably, find the sound quality to be pretty poor.
Please, let me know if I can help you any further.
Regards, Carlos
I lost my instructions on how to pair my sennheiser vmx 100 with my motorola razr. can you help
Have your phone do a search for Bluetooth devices (have the earpiece turned on) and when it locates it, type code "0000" to pair.
Sennheiser mm200 totally dead
Well I have had the same problem as well, twice really. The first one got replaced by Sennheiser, very good service. Unfortunately about a year later the same problem, I am waiting now what they will do with this. I really like the little earphones but I need them to work. Untill now I have had great service which of course comes with the quality of the name.
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
