Take to a Samsung shop.
First thing is you need the latest version of the Samsung interface software so the phone is properly recognized by the computer for syncing
Here is a link to that software for windows :
https://www.solvusoft.com/en/update/drivers/mobile-phone/samsung/gsm-2g/gt-c3303/model-numbers/
For updating the phones software itself :
Go to menu / settings / system upgrades/ check new version
- hope that helps :)
SOURCE: my samsung champ gt-c3303 not
my samsung champ touch phone gt-c3303 not connected 2 d internet via pc,how can i solve my problem?
SOURCE: I want to connect laptop for internet using with
you need to download samsung kies software.. and install it. then automatically the required drivers will also be installed.. then follow the instructions as below..
NOTE: following instructions are for tata docomo internet. names may vary depending on your mobile network.
you just connect with bluetooth or data cable and find out the modem then u goto control panel ->phone and modem option then dialing rules tab ->new -> country/religion fill India and area codeand then ok. and then goto same dialog box in modem tab n select modem click ->properties and then advance tab n fill in extra initialization commands: AT+CGDCONT=1,"IP","TATA.DOCOMO.INTERNET" and then ok.
goto control panel ->network connection ->create a new connection ->new connection wizard next ->choose connect to the internet ->next ->choose setup connection manually ->choose connect using to dial-up modem ->next ->isp name -tata ->next ->phone number- *99# ->next ->next ->finish
then you a dialing tata icon in the desktop and you r connect internet in your pc
Just a pro tip :
ALWAYS back up your phone and computers before you update operating system software on either device!!!!
- in case the update does not install correctly, your data will be safe
