Fender Musical Instruments Corporation Fender Rumble 15 Bass Guitar Amplifier Amp Pak Logo
Posted on May 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It plays for about 30 minutes and then just stops, as if overheating. After a cooldown period, it starts up again for another short period. Suggestions? Any recommended vents I could cut in it? Tia. Norm
rev robert cornell
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on May 16, 2015
rev robert cornell
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
4295
Points
53
Thermo overload prob chip heating up
Fred Yearian
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Fender Master 5,603 Answers
  • Posted on May 24, 2011
Fred Yearian
Fender Master
Level 3:
Answers
5603
Questions
Helped
2248554
Points
16162
The small Fender products often have a TDA2050 power chip in them. The chip is on a thin aluminum heatsink and is intended for light use. If you try to sound like a bass guitar amp with this, the chip will go into thermal protection mode. Cutting vents will not help very much, and pushing it to these levels will destroy the speaker eventually. If you need more power, buy a bigger amp. This one would be suitable for a 10 foot by 10 foot room.
Fender Frontman 212R
sounds like bad caps and maybe a failing output transistors. Use Deoxit contact cleaner too.
1helpful
Suddenly stops working and have to wait for a few minutes for it to work again.
Probably a component in the power supply is overheating, You need to take it to the repair shop.
2answers
I have a Kustom HV 100 hybrid tube amp. When I power it up, It will play normal for about 5 seconds and then the volume drops off. The preamp tube is only about 2 months old and this amp only gets played...
After the volume drops off, let the unit sit idle for a minute and then try it again. If the volume has restored for another brief period, suspect the filter caps are weak and voltage drops when you start driving the unit. In any case you need to have it serviced. Unless you can see the heater in a tube going out with vibration this may not be a DIY repair. If you see purple glow in a tube, replace it.
2answers
My Dual Terror amp stops working just a few songs into my practice session. The best way I can describe it is that it's like a battery going dead in a guitar with active electronics. The volume...
Instead of waiting a day, cool the thing down as quickly as you can and try it to see if it is a therma; problem.
You MAY be driving it too hard and the amp chip is going into thermal shutdown... This is a small amp and not intended for major loud use.
TRY playing softer and see if it lasts longer before failing. If you are overheating the internal chip because you want it loud, best to get a bigger amp...
Next test is to turn it on but DON'T play for a time period of more than the usual few songs and then see if it is already dead or you have to play awhile before it fails.
My 410 deville's channel switching doent work and is stuck on the clean channel. This really isn't a problem as I always use the clean channel and I only mention this in the event it helps diagnose the...
You may have a switch that may be bad. For the sound level high and low may need new tubes or possibly may not be seated fully into position. These tubes due get quite hot and do get loose over a period of time.Hope this helps.
My p.a. amp makes a loud bang after ten minutes
DO NOT use while this problem exists as you may damage your speakers.
You may be overheating the unit and the thermal cutouts may be opening... CHECK that the fans and vents are all in good order.
Check that you are not putting speaker loads LOWER than the rating of the amp onto the amp.
May 15, 2010 • Music
5helpful
3answers
Marshall MB4410 - Dies and comes back to life every few minutes..
Our bassplayer had the same problem with his mb4410. As it turned out, the fan was not working when the amp got hot. It did turn when cold - go figure! Swap the fan for a good quality (Pabst, Sunon) 80mm pc fan with 2-wire connection. Three or four wire fans will not work w/out modding. See your local pc guy and ask for an unregulated, silent 24/7 fans. He will know. Our bassplayer sold the P.O.S. while still in warranty. HTH.
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
