Kettler Mondeo Elliptical Trainer Logo
Posted on May 24, 2011
No power cord no display - Kettler Mondeo Elliptical Trainer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 16, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1218
Points
I have a kettler derby exercise bike, but inside no case battery only display ,do i need to buy a new display ?
2answers
Cross trainer. Why isn't display working?
If your elliptical trainer does use an electrical outlet for the power supply, unplug your elliptical trainer and then check the power cord. Replace the power cord if it is frayed or damaged . If the power cord is intact and properly connected to the console, then you might have to replace the console when the elliptical display screen is not working.Or the screen could be broken and needs to be replaced.
Power cord for a fujitsu 42" plasma display model no. p42hha40us
http://www.amazon.com/dp/B004M8S012/ref=asc_df_B004M8S0122466179?smid=ATVPDKIKX0DER&tag=shopzilla_rev_185-20&linkCode=asn&creative=395093&creativeASIN=B004M8S012
took hours to find hope this works.
2helpful
2answers
ALWAYS SHOW " 1024 X 768" HERZT. CAN'T SHOW
Hi, Same problem as mine! Are u suing the original Samsung CX511n cable? If not, video will not appear! Buy the original cable!
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
12helpful
2answers
My c7180 keeps coming up error OXC18a0201 Ink system has failed, it says to shut off, and I have and it comes right back
Problem occurs for me when i run too long with an empty cartridge solution press * and # at the same time press 1 2 3 and "support R0632M" should display press > and "information menu" should display press > and "configuration menu" should display pres OK and "hardware failure status" should display press OK "failure status:clear" Press OK to clear press cancel press cancel press cancel turn printer off unplug power cord for two minutes plug back in power on use your printer
HP Photosmart printer Ink System Failure Error 0xc18a0201 happens every time I start it.
You press the button to turn off the printer.
Unplug the power cord from the back of the printer. Unplug the power cord from the back of the printer.
Remove all the ink cartridges. Remove all the ink cartridges.
Wait two minutes. Wait two minutes.
Plug the power cord into the back of the printer. Plug the power cord into the back of the printer.
Press the On button to turn the printer on. You press the button to turn the printer on.
Install the ink cartridges when prompted. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the error code does not display, the issue is resolved.
Carriage Jam Error display on the LCD!
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
3answers
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Top Kettler Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
mbeta adjou
Level 1 Expert
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
